Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Avenger disengages in drive wont go forward
Old Mar 9, 2026 | 08:15 PM
Lucylling's Avatar
Lucylling
Default Avenger disengages in drive wont go forward
2014 dodge avenger sxt v6 went into limp mode so I had the solenoid to the transmission changed, did a relearn on it, it goes through all the gears, disengages in drive and wont go forward but drives in reverse good. I put a code reader on it and code p0871 kept coming up. Does anyone know what could be causing this and how to fix it?
Old Mar 10, 2026 | 07:33 AM
What causes the P0871 code?
The P0871 code has a number of common causes:
  • Low transmission fluid
  • Faulty transmission high pressure pump
  • Broken or dirty transmission temperature sensor
  • Slipping or malfunctioning transmission
  • Faulty powertrain control module
  • Overheating engine
