Hello..Welcome to the Avenger Section
As many know, the 1995-2000 Dodge Avenger is quite a bit different from the new 2008 Dodge Avenger. There are no threads that apply to both generations of the Avenger, so above this thread you will see a section for each of the Avenger types. Please use those sections for your questions on either your new Dodge Avenger, or your 1995-2000 Avenger coupe.
my 1995 avenger has a 2.5 24valve engine i was driving, and it just stoped working
it will turn, but there is no spark in the plugs what is the problem ? and what does the (asd ) look like and were can i find it? |
there are three relays on the firewall ...
first do you hear the fuel pump fire when you turn the key ??? ASD= Auto shut down it stops the car if there is no 12 volts to the fuel pump ... in the 95-00 section there is a sticky on the relays |
Can someone suggest 3-4 good accessories for Dodge Avenger?
I m interested to buy a second hand 2008 Dodge Avenger. Can anyone suggest some useful information about this.
Originally Posted by Jeffry
(Post 2212526)
(Post 2212529)
i would suggest u to check the fuse and switches on ur avenger.
hi
Originally Posted by expendables#1
(Post 3234467)
