07 Dodge Caliber rear strut replacement
Welcome Aboard DrDurangoDave! Stay tuned - a Technician (or member) will jump in shortly to answer your question. In the meantime, don't forget to browse Sub-Forums: Durango for stuff related to your ride.
on
Welcome to DF
Rear Suspension/SHOCK ABSORBER, Suspension, Coil-Over/Removal
REMOVAL
NOTE: Before proceeding.
1. Remove the interior rear quarter trim panel.
2. Remove the two nuts securing the shock assembly to the body bracket.
3. Raise and support the vehicle.
4. Remove the wheel mounting nuts, then the rear tire and wheel assembly.
5. Remove the shock lower mounting nut and bolt.
6. Lower the shock assembly out of the body bracket and lift out over rear suspension.
Hope this helps, I will be moving your post to the caliber section.
REMOVAL
