Wont start
on
DIAGNOSIS:
1. With the condition present (i.e. the vehicle in the no crank / no start condition), connect
the StarSCAN® scan tool to the vehicle.
2. Turn the ignition switch to the “ON” position, and power up the StarSCAN®.
3. If the WCM is electronically locked up, the StarSCAN® will display the WCM as being
“off bus”.
4. If the no crank / no start condition is present, and the WCM is “off bus”, then reset the
WCM by temporarily removing the IOD fuse (with the key out of the ignition switch),
wait for 10 seconds and then reinstall the IOD fuse.
5. With the IOD fuse reset having been performed, verify that the vehicle will now crank,
start, and run.
6. If the condition is temporarily corrected by performing the above steps, and if the part
number of the WCM is earlier than the part number of the WCM listed in the part
reference table in the Service Bulletin Parts Required Section below, then perform the
Repair Procedure
“off bus”.
start, and run.
Repair Procedure
DIAGNOSIS:
“off bus”.
start, and run.
Repair Procedure
“off bus”.
start, and run.
Repair Procedure
