Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Dodge Caliber 2010 central locking not working
Old 01-25-2015, 05:43 AM
sebbat's Avatar
sebbat
sebbat is offline
Default Dodge Caliber 2010 central locking not working
suddenly its not opened and not working for now
also room lamps not working and light where transmission handle is - P R D N
I have checked all fuses and contacts - remote works but also not close/open locks, buttons on the door also not working
Old 01-25-2015, 06:42 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Welcome to the forum.
None of the doors lock or unlock electrically?
Old 01-26-2015, 03:32 AM
sebbat's Avatar
sebbat
sebbat is offline
Yes, none. Not one. Only mechanical
Old 01-26-2015, 06:48 PM
SSVhI's Avatar
SSVhI
SSVhI is offline
I read online that a "shock" from static can reset your key fob, and you have to go to the dealership to set them, however have you tried disconnecting the battery for 10mins and then trying the locks?
Old 01-27-2015, 02:32 AM
sebbat's Avatar
sebbat
sebbat is offline
already tried disconnect battery and erase all faults by scanner - nothing. My key fob is forking, its ok, but locks not working not from key fob, not from buttons on the doors. All modules doesn`t have faults - only gateway - right beam lamp is off. Door and passenger door module not response.
Old 01-27-2015, 11:47 AM
SSVhI's Avatar
SSVhI
SSVhI is offline
idk about your headlamp but have you taken the interior panel off and disconnected the power switch modules and then re-plug them in? the interious panel is generally held together by 5-8 plastic clips, I haven't personally taken my cars interior panel off so im not sure how many clips there are, but maybe the modules that control the locks have come loose in the door or the linkage in the has but probably not the linkage if you can lock & unlock manually just the electronic modules
Old 01-27-2015, 05:11 PM
sebbat's Avatar
sebbat
sebbat is offline
I think disconnect battery is the same, and lock can`t working without dashboard
Old 01-28-2015, 08:50 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
I am sorry to hear you are experiencing issues with the door locks and lights. Are there any fault codes? Listed below are possible causes for the door lock issue. Did you rule out the bulb for the headlamp issue?
TIPM FUSE NUMBER 10 OPEN
(P33) DOOR LOCK DRIVER WIRE OPEN
(A932) FUSED B+ CIRCUIT OPEN
INSTRUMENT CLUSTER
__________________
Regina
U.S. Top Care
FCA U.S. LLC
Old 01-28-2015, 05:17 PM
sebbat's Avatar
sebbat
sebbat is offline
will check all ideas in the end of week, have some...
Quick Reply: Dodge Caliber 2010 central locking not working
