Windshield fluid nozzle--only passenger side
The windshield wiper nozzle fluid sprays fine on the driver side and rear window but nothing on the passenger side. I doubt its the fuse or pump given the fact it only affects one side. Could it be blocked? is this easy to do?
It could be blocked, or the hose has cracked or come off. You can take a small sewing needle and try to poke thru the hole in the nozzle. Check and make sure fluid isn't spraying under the hood from a hose issue.
