Electric Super Charger
I have Dodge Caravan 2.4L 97 model, is it safe if i will put electric super charger to my caravan? I need advice from anybody. Thanks
RE: Electric Super Charger
I think it is safe, but I also think you will be disappointed. A supercharger normally needs lots of horsepower to be effective, and electric ones don't have enough power. It's almost shocking but a mechanical supercharger can generate 100hp but uses 60 of it to do so--that gives you an idea of the energy required. My guess is those electric jobs consume maybe 2 hp (in electrical load)so I can't imagine what they can generate.
I have to agree with Next you will be disappointed the electric motor is not powerful enough to push the air needed what I would suggest but is costly is a turbo charger they make them for the 2.4 and you'll get much more performace that way I would look under the Neon section as A LOT OF GUYS put turbos on the 2.4 you might be able to get one cheaper used out of a wrecked car though
The 'electric superchagers' being sold are actually a Metro Vacuum cleaner product that is meant to inflate white water rafts with 12 volt power. I have owned one for years...I think I bought it for about $45...and I can tell you it does not put out much over 1 psi maximum.
http://www.lonelyplanet.com/bookings...ump_12volt.htm |
Thank you for the replys brother, I will not waist money for turbos on my caravan. Your advice helps me alot.
ORIGINAL: vlmuke what I would suggest but is costly is a turbo charger they make them for the 2.4 and you'll get much more performace that way I would look under the Neon section as A LOT OF GUYS put turbos on the 2.4 1) You must also borrow the Engine Managment system from Turbo Neon. a. ignition timing must advance during decelleration, e.g. intake manifold vacuum. (this already occurs withnormally aspirated (n/a) engine) b. ignition timing must retard during accelleration, e.g. progressively with increased rpms c. ignition time must retard when knock is detected by knock sensor 2) You must also borrow Fuel system from Turbo Neon. a. highpressure electric fuel pump b. fuel pressure regulator must increase fuel pressure 1 psi for each additional corresponding 1 psi of intake manifold boost, e.g. from turbo. 3) You may need to borrow engine from Turbo Neon. a. verify crank/rod bearings are strong enough. b. verify exhaust valves are strong enough. c. verify cam specs are suitable for increased compression resulting from boost. d. verify that compression ratio of pistons is less than 8.5:1. You may get away with 9.0:1, if you keep turbo boost below 10 psi. 4)You will need additional guages a. Wideband O2 sensor and Wideband Air/Fuel Mixture gauge b. Boost gauge (start with 5 psi of boost and gradually increase to 15 psi -- keeping an eye on Wideband A/F gauge and ignition timing throughout all rpm ranges. This isn't as difficult as it seems at first. I know many people (Do-It-Yourself home mechanics who are comfortable with swapping out engines and electrical wiring harnesses) who have made turbo-versions out of their normally aspirated vehicles. All were built using common salvage yard parts. I would love to see a Turbo Neon 2.4L swapped into a Caravan. Does anyone have any pictures to show? |
Robert I agree with you thats why I directed him toward the neon forum to see what is entailed in installing a turbo rather than have you or some else spendenergy typing what you did
