03 Caravan Radio Problems
RE: 03 Caravan Radio Problems
Is this a factory radio or an aftermarket??? Some aftermarkets have an actual mini computer inside them and possibly it could be going bad. Disconnect the negative cable on the battery for a minute or so.and see if it comes back. I say that because if you pull the fuse for the radio..depending on how its wired.it may still have power going to it for memory.ect. Good luck
