Brake Question
RE: Brake Question
If I'm not mistaken, if the modulator fails, it should default to a convntional braking system. If it's partially or intermittantly working, you may be able to just pull the fuse for the ABS system to make it act like a conventional set of brakes. Holtzer and Master-tech probably have a little more insight into this. Good Luck
