front end clunk
front end clunk
We've got an 02 Caravan se that has a klunking noise in the front end. It is there only when it's cold outside. It is there when you hit bumps. However when I check the front tnd for play, none is readily evident. Then once it gets above 50 degrees outside, no clunk. Anyone know whats; going on here? It is a four banger if that makes any difference.
RE: front end clunk
I'm dying to get polyurethane bushings. I've scanned Energy Suspensions' website and they don't make any kits. I'll probably do some measuring and try to find "universal" bushings. I'll let you know what I end up with.
Won't be for a while. Got too many things on my plate right now, but I'll get to it.
Trending Topics
RE: front end clunk
My experience with my 2002 GC is that the right side (passenger's) bushings and sway bar links wear out more readily than the left side.
If I heard the famous clunking noise (which sounds much worse than the problem is) I would check the right sway bar link for wear / looseness. Two tie rod end type connections are used here. If defective I would replace with a sway bar link that has grease fittings instead of being sealed, keeping in mind that those that grease the vehicle will need to be asked to grease the fittings as they aren't the norm.
I would check the left sway bar link as well to ensure it was okay. If not, I would replace it as for the right side.
If still "clunking" Iwould then move to the right side sway bar bushing and replace it. Polycarbonate seems to be readily available. Go with it for the replacement.
The only thing left is the left sway bar bushing which, if you have ABS brakes, is much more difficult to work on (interferences) than the right sway bar bushing.
The sway bar bushings can be replaced with the vehicle on a ramp, no need for jack stands. Sway bar links, on the other hand, will require jacking up the vehicle for better access.
RE: front end clunk
the reason the right side tends to wear out sooner especially in the snow belt is all the slush and road debri on the side of the road constantly splashing onto the vehicle. i've seen enough of these fans that I would honestly start with the bushings at $7 and some odd change apeice its not bad. look for shiny metal on the sway bar next to the bushing indicating it is moving.
