please help identify this pulley!
hi all,
so the serpentine belt flew off in the pouring rain tonight, i put it back on figured out the right way to put it back on and drove it home as it began to overheat. the pulley circled in the pic is the one thats bad, it is not a ribbed pulley but a smooth faced one. please help so i can replace this thing and get my grocery hauler back on the road lol
There's several easy ways to solve this problem... unfortunately I doubt you have the tools (I use a welder as part of the removal process. Also If I feel one about to break, I stop there and devise a plan to remove the rest without breaking them. The old saying... an ounce of prevention is worth a pound of cure. Oh and to make access a bit easier, support the engine, separate the front engine mount and lower the engine, You'll have a straight shot at all the bolts. Also if you soak them with PB blaster this will help. A little heat on the aluminum housing also helps but don't go nuts with heat.
