#3 Cylinder Misfire on idle
Hi guys
I have a Grand Caravan 2005 with the 3.3 engine. I can notice some rough idling especially when transmission in on "D" because RPM is slightly lower than when in neutral. The check engine light is on. I went to the dealer to read the code and he said it was #3 cylinder missfire. Spark plugs were replaced about 1 year ago. I ordered the #3 spark plug wire from Dodge and replaced it myself, still same problem. When i am driving everything is fine, it looks like misfire happens only on idle because of the low RPM. Some day i can't feel any misfires, so i doubt i can be a bad spark plug cause it would do it all the time. Any ideas ? Thank you |
if the cel is on take advantage of the free scan at some parts stores ie autozone ..........post the code pxxxx. someone will advise.
knowing the exact code may avoid guessing |
Cylindre 3 missfire is P0303 on any car
Start the car, let it idle in park Take a bottle of spray water add salt in it (half a teaspoon seriously)n spray the wires the plugs and the coil....(coil is at other end of wires).....look for lil sparks..... |
he was told by someone ... big differance from KNOWING actual code
If the dealer says its p0303 the custumer will say what the **** that means.....mechanik will answer its missfire on cylindre 3.....how is that not clear???? |
it is not clear to me- any other codes?.. "hear say" another profession would say
