keyless entry remote question
Re-Programming an 02 Dakota Keyless entry Key FOB
I just purchased a used '02 Dakota SLT & had to have a module replaced that controlled the lights, turn signals, & AC... this left the key fob key-less entry un programmed. I read the thread on reprogramming these but I want to be sure these instructions apply to all models - cars & trucks. If not please direct me to the appropriate thread. Thanx.
on
Welcome to DF
You do know you posted in the van section? Don't worry i won't kick you out. We are here to help.
STANDARD PROCEDURE - RKE TRANSMITTER PROGRAMMING
New Remote Keyless Entry (RKE) transmitters can be programed using the DRBIII® scan tool and the proper Diagnostic Procedures manual, if no functioning transmitter is available. The DRBIII® scan tool can provide confirmation that the PCI data bus is functional, and that all of the electronic modules are sending and receiving the proper messages on the PCI data bus.
The following procedure can be used as long as one functioning transmitter is available:
Turn ignition to the RUN position (allow ignition chimes to stop).
Using any original (working) transmitter, press the UNLOCK button for 4 to 10 seconds.
Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and press the PANIC button for 1 second, and release both buttons. A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
Press LOCK and UNLOCK buttons simultaneously for 1 second and release.
Press and release any button on the same transmitter and a chime will sound, or locks will cycle after successfully programming the transmitter.
Repeat steps 5 and 6 to program additional transmitters.
Turn ignition to the OFF position. Transmitter programming mode will discontinue after 30 seconds. All transmitter programming must be completed within time specified.
Welcome to DF
Thanks in advance,
coke_o
The part number to the new key is different than the part number to the original key. However, I've called like 5 different area dealerships an they all give me the same part number (the part number that the new key has). I give them the vin and they confirm that it is indeed the correct part number.
