DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   Dodge Caravan (https://dodgeforum.com/forum/dodge-caravan-23/)
-   -   97 GC AWD: starts, won't idle (https://dodgeforum.com/forum/dodge-caravan/267544-97-gc-awd-starts-wont-idle.html)
vanx3 Nov 5, 2010 04:39 PM
I have checked spark plugs & wires. Then did a compression test that seems to show no compression in center back cylinder. So now I want to pull the intake and valve covers to maybe see why. First step: drain coolant. I turned the valve at the left bottom of the rad - nothing comes out. Rad is full. Tried air back into valve but it acts blocked. Ideas?
Tizzy1 Nov 5, 2010 08:41 PM
does it miss when you rev it up? If you have no compression you should have a dead hole and a misfire but it should still idle. As for the radiator, did you turn it far enough? The drain plug kind of unscrews from the radiator.
© 2026 MH Sub I, LLC dba Internet Brands
