Noise when turning... opinions wanted
2005 Dodge Grand Caravan
While driving when I turn left, which puts weight on the front right wheel I get some well loud road noise sound. No clunking, no metal on metal just lack of cushion on the front right wheel. So I jacked the vehicle up and shook the wheel. There was looseness from left to right but not up and down. I noticed play at the tie rod end so I replaced it. The play was gone yet the noise wasn't fixed. So I replaced the wheel beering hub assembly... what a pain btw. That did not want to come off. So after a few busted knuckles, a couple beers and many swear words it appears not to be the issue. So after reading around about the sway bars always being afu I am tempted to change that now but really would like opinions before I continue to replace everything. Thanks! |
Welcome to DF
Do you still have the old hub bearing? If you do put it on the other side and ck for any noise. Sway bar bushings would be a clunk sound or rattle sound. |
Originally Posted by master tech
(Post 2314768)
Welcome to DF
Fluid levels are fine.
Have you try moving the rear tires to the front?
(Post 2315663)
