CEL's
Hi all,
I am wondering what make/model scanner some of you guys are using to check engine codes in your DGC's and where does it connect in the van? Cheers. |
Innova 3030 It connects to the OBDII under the dash
You can get most of the codes by turning the key on, then off 3 times and leave it on the third time. If there are any codes they will come up in the odometer window. If there are none it will say done. Be prepared to write the numbers down as they well only show for about 5 seconds before the next code comes up. It will say done at the end. The numbers will be proceded by a 'P'.
A list of the codes is available on this forum. Look for MIL codes. |
| All times are GMT -4. The time now is 02:44 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
