Grand Caravna problem
My wife put gas in our 2005 dodge grand caravan. Not long after the engine started sputtering. I ran the codes and pulled p0202 and p0302. Any ideas what is wrong? Fuel injector maybe?
whats the chance that the fuel injector and spark plug went bad at the same time?
Practically nill. A faulty injector can flag both codes as stated in the links. Check injector pulse using a noid light you can sign out from AutoZone or the like for a deposit. If it doesn't light up you may have an open wire, poor connection or faulty PCM.
Before i even had a chance to look at it, im now getting error code p0300, which i believe is multiple cylinder misfire. Any ideas what to look for now. or should i just start changing plugs and go from there?
