Possible to add power windows to base caravan 1996?
Is it possible to add power windows to the 1996 base model Caravan? Its manual everything except the mirrors.
Is the Body Control Module capable? Mostly interested for the drivers side, but all I would need is the window switches for the door and motor or its a bit more involved? |
This is a old thread but just wanted to put this out there.
Yes, I added to a 1999 SE with 2.4L. I got the wiring in the door from junk yard and had to add power in the power block above the brake pedal. The wiring to the door jam is in place. I just soldered to the power block and connected to fuse panel or could wire battery via fuse to block. You need door switches and window regulators/motors. So , feed power to power window circuit on power block. Get wiring harness inside doors , door switches and window regulators. |
