caravan 2014
Hello everybody just looking for input and maybe an answer.
I bought my Caravan in November 2014 and have had a vibration in the front end since. I have had at least two alignment, 5 wheel balancement and got my wheels road forced twice and still have a vibration. All under warranty so didn't pay for it. any input from experience would be nice. |
Specifically when does the vibration occur? Sitting still? While driving? Does it increase/decrease with speed? only happen at a constant speed? Only does it while braking? Cornering? Please be a little more specific, it could be anything.
sorry my mistake, so the vibration start at around 80km/h and increases as we go faster.
It feels like the whole van vibrates. |
What is your model year and type of engine?
my model is the SXT 2014 and i have the 3.6L engine in it.
A couple of oddball thoughts since you've already done the obvious:
- Is there anything on the exterior of the car other than the factory roof rack that would affect the car's aerodynamics (e.g., ski rack)? - Has the dealership checked for loose suspension hardware, axles/CV joints, tie rods, etc? - Does it only vibrate in the winter? Ice accretion on the wheels can cause vibration that a dealership might not be able to replicate. - Does the vibration occur if you rev the engine while it's in park or neutral? This might indicate a bad motor mount. If you bought the van new you also might consider looking into whether your jurisdiction's lemon laws apply here. |
There is a TSB for the front brake rotors that could be related to what you're experiencing:
TSB 05-005-14 REV. A SUBJECT: Steering Wheel And/Or Seat Vibration - Front Brake Rotors OVERVIEW: This bulletin involves inspecting the Julian date and if necessary, replacing the front brake rotors. MODELS: 2014 - 2015 (RT) Chrysler Town And Country Dodge Caravan Ram C/V Tradesman NOTE: This bulletin applies to vehicles built on or after June 01, 2014 (MDH 0601XX) and on or before August 01, 2014 (MDH 0801XX) equipped with Anti-Lock 4-Wheel-Disc Brakes (Sales Code BRG) or Anti-Lock 4-Wheel HD Disc Brakes (Sales Code BR3). SYMPTOM/CONDITION: The customer may describe a shake and/or vibration in the steering wheel and/or the seat while driving at highway speeds without the brakes applied. This vibration may be caused by out of balance front brake rotors. |
They should focus on axle shafts at this point.
