Tire trouble light?
How do I get it to go off, tire pressure is spec.
A little background info would help.....
Originally Posted by jkeaton
(Post 3445168)
Presumably you drove the van for a few miles and TPMS light didn't reset. If you've got the EVIC as part of your instrument cluster you should be able to scroll down to see each individual tire pressure. 2018 still should be under warranty bring it to a dealer let them diagnose the problem might just be a sensor gone bad.
Thanks Mopar, where would that EVIC be?.. if I have it.
It's should right above the gear indicator between the Tachometer and Speedometer.
Thanks again Mopar, guess I should read the owner's manual, haven't played with them buttons yet.
