[5th Gen : 08+]: 2011 Grand Caravan - P0303 & P0420
I was driving last night in my older Grand Caravan with 270,000km on it when I floored it and suddenly it started misfiring and shuddering. I tried taking my foot off the pedal to slow down but it got worse so I kept it steady at 80km/hr. The whole ten seconds this is going on the dash is chiming and the check engine light is flashing, however this was temporary and I was close to home probably under 5km and didn’t notice anything else on the way back, also idled it this morning no problem.
I have an OBD2 Scanner from Innova and put the freeze frame information for the P0303 code in a spreadsheet
FUEL SYS 1
OL DRIVE
FUEL SYS 2
OL DRIVE
CALC LOAD (%)
100.0
ECT (F)
185
STFT B1 (%)
0
LTFT B1 (%)
0
STFT B2 (%)
0
LTFT B2 (%)
0
MAP (inHg)
27.8
Eng RPM
4991
Veh Speed (Mph)
55
Spark adv (.)
15.0
IAT (.F)
37
TPS (%)
86.7
RUN TIME (SEC)
192
COMMAND EVAP(%)
0.0
FUEL LEVEL (%)
33.7
BARO (InHg)
28.6
ECU Volts (V)
14.437
LOAD Value (%)
103.5
EQ Ratio
0.895
Rel TPS (%)
76.1
AMBIENT (.F)
30
TPS B(%)
86.3
ACC Pedal D(%)
91.4
ACC Pedal E (%)
45.5
Command TAC (%)
76.1
if I have to replace the cat I think I will just scrap the car so hopefully nothing expensive! I appreciate any insight or solutions!
FUEL SYS 1
OL DRIVE
FUEL SYS 2
OL DRIVE
CALC LOAD (%)
100.0
ECT (F)
185
STFT B1 (%)
0
LTFT B1 (%)
0
STFT B2 (%)
0
LTFT B2 (%)
0
MAP (inHg)
27.8
Eng RPM
4991
Veh Speed (Mph)
55
Spark adv (.)
15.0
IAT (.F)
37
TPS (%)
86.7
RUN TIME (SEC)
192
COMMAND EVAP(%)
0.0
FUEL LEVEL (%)
33.7
BARO (InHg)
28.6
ECU Volts (V)
14.437
LOAD Value (%)
103.5
EQ Ratio
0.895
Rel TPS (%)
76.1
AMBIENT (.F)
30
TPS B(%)
86.3
ACC Pedal D(%)
91.4
ACC Pedal E (%)
45.5
Command TAC (%)
76.1
