stalling after engine warms up to 180-+
my 97 grand caravan(3.3 liter)has developed a problem where it stalls out and will
not restart till engine cools off.this happens at around 180 degrees as it warms up..it was throwing codes for crank sensor and or cam sensor..replaced both..still happening..any ideas?? |
I have the same problem with my 1996 ram van. Did you discover a fix?
Hi I have the same issue, but no codes. Can't spot the issue, please reply if any updates.
What I've done is add a switch to the fans relay to turn on/ off the fans manually before it reaches the middle of the temp gauge in dashboard. Mine is a 2001 SE 2.4L |
