electrical problem 93 caravan
Originally the van would run for 45 seconds and stall. If you recycle the igintion switch, it would restart and run for 15 seconds. I have replaced the fuel pump, computer, oxygen sensor, crank sensor. The van will now run but is erratic. It flashes codes 31, 32, 42, and 53. These codes will appear on the scanner, then disappear. I think I have a short to power but don't have a clue on where to look.</P> HELP!</P> |
I guess your van would fall under this category. If not then this info is not correct.</P> <U></U></P> <U>Chrysler/Dodge MPFI Lt Duty Trucks & Vans 1989-1995</U></P> 31-Purge Solenoid Circuit </P> 32-EGR System Circuit </P> 42-Auto Shut-down relay circut</P> 53-Internal self test</P> http://www.troublecodes.net/chrysler/</P> |
