strut towers
hi gang im new here and hoping for some help or advice. i recently got a 96 caravan 3.0 for a buck theres to main things wrong with it the strut towers under the hood are rusted out badly and it needs crank seals both ends it has 300,000 Ks on it but everything else seems good runs quite, would i be able to do the seals with the engine in by dropping the mounts as i go and could the strut towers be repaired or replaced? would it be worth it ? after all i did get for a buck. thanks in advance.
RE: strut towers
ORIGINAL: dogz46 the strut towers under the hood are rusted out badly ..... and could the strut towers be repaired or replaced? would it be worth it ? http://www.makeitmopar.com/ lists the strut towers under body repair/fender/structural components and rail/strut tower you would have to call them to see if they can actually get them though. |
