Rattel noise
I have a very annoying rattel noise in my cab. It seems like its coming from the headliner or the sunglassholder/garage door opener. Can anyone relate???
RE: Rattel noise
It could be your sunroof.
RE: Rattel noise
I have the same rattle - it's the sunroof. Had it in to the dealership and they "fixed" it - so they say. It still makes noise - just gonna live with it for now.
RE: Rattel noise
My sunroof rattles too. It started on the driverside just above my head, if I push up on the headliner just to the side of the sunroof directly above me it stops. I recently noticed the passenger side is doing it too. The rattle only exists with the roof UP not back or closed. There is a knob on the dash that makes it go away, it is to the left of the radio called VOLUME. I have noticed this knob silences the other minor rattles too.
RE: Rattel noise
I fixed the same noise in my Daytona, it is indeed the sunroof. There are two nuts one on each side at the front corners of the sunroof assembly that are loose. Pull the rubber trim around the headliner at the sunroof hole then with skinny hands and a long 10mm wrench you can tighten up the nuts at the front corners of the sunroof. Viola rattle gone. I was about to turn mine into a convertible untill I figured it out.lol. Hope this helps
Brian |
RE: Rattel noise
....I dont have a sunroof.
RE: Rattel noise
Well a sawze all and a little time and that convertible thing might work, sorry couldn't help myself. I've found a lot of rattles are stuff my wife puts in all the little storage bins, sunglasses can be the culprit too.
