Dodge ChargerThe Dodge Charger. The car that made its competitors shiver in the 60's is reborn in 2006 into a sleek sedan that can still send the competition home wimpering, the Dodge Charger.
left turn signal flashes very fast. Right signal ok.
I have found that with car off, ignition turned on signal flashes normal. Start car and signal still normal. Put car in drive and signal flashes very fast. Dealer wants $350. 00 to fix. Sounds like a lot.
What did they say is wrong with it?
flashing fast is usually the a bad Light Bulb, does the turn signal itself work? front and back? Any Aftermarket LED light installed?
Trophy,
What did they say was the cause? I would replace left side turn signal bulbs on front and back before I spent $350.
