Need Tires Already WTF!!!????!!!!
Needs tires already???
8552 Miles and all 4 tires are at 3/10 wear. This is a brand new car with factory tires. Can anyone recommend a tire that will get atleast 20000 miles or so. All Season is much preferred and must be 20 inch's and 245/45 ratio or bigger up to what will fit and not rub. |
Ask your local tire store. And stop driving it like you stole it. :pi
Originally Posted by jkeaton
(Post 3356245)
If your looking for best tread wear they may not be the best handling or gripping tires .
Sticky / performance tires usually don't have as high of tread wear ratings, they wear even faster when pushed hard. You 1st have to decide your priority tread life or performance , or maybe something of a compromise as tires are purpose built. |
No matter what you should have gotten more.
Its pretty common factory tires wear faster. Wouldn't there be a factory warranty on the tires? To get the warranted tire wear on any tire you would most likely have to drive it like you have an egg on the gas and brake pedal. |
