Losing Oil; Normal At 190k?
My 2006 Charger is running through roughly a quart every 1,000 miles. I'm currently sitting at 190,322 miles and just changed the oil. In the 5qt jug I used to hold the old oil, it only showed 3.5qt.
No real signs of damage but I'd like to gauge how often to add oil. There's no leaks, no fumes, or exhaust issues. |
Probably rings and/or valve seals. Do you get a puff of smoke at cold startup?
Think I would be checking the oil every time I filled the tank. Just to be sure. :) |
(Post 3416697)
Originally Posted by AKCallahan
(Post 3416784)
No puff of smoke at all to mention. I'm astonished at the rate it's burning but nothing visible or odor noticeable.
Doing a dry, then wet compression test will likely tell the tale. |
