Code p0128
Old 11-14-2018, 04:46 PM
furiousgeorge's Avatar
furiousgeorge
furiousgeorge is offline
Default Code p0128
Hello, my 2011 Charger SE (3.6) has been throwing this code now and again over the last few weeks, my cheap scanner says “coolant temp below thermostat regulating temp”. I’m assuming this means the thermostat isn't behaving properly, as the coolant level and strength is right where they should be. The temp gauge is always dead on where it’s always been, so I’m not overly concerned at the moment.
My question is what is the best brand thermostat for these engines? I’ve heard of people using thermostats that are a different temperature then stock, what is the reason/advantage to this?
Thanks!
Old 11-16-2018, 09:44 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Use a stock temp thermostat. There is no advantage to using something cooler. You actually get worse gas mileage that way, as the computer tries to get the engine up to the temp it thinks it should be. (not to mention, that once it figures out that it CAN'T, it will whine about that too.)
Stant makes good stats. Do NOT get one of the 'safety stats'. They fail far to easily.
Before digging into it though, I would be tempted to see what temp the pcm thought the engine was, and verify that with a temp gun, or some such. Might be a bad stat, might be a failing temp sensor.
Old 11-18-2018, 05:41 PM
furiousgeorge
Thanks! I’m no sure if my crappy scanner will tell me actual temp, but I’ll give it a try on the next warmish day.
Old 11-18-2018, 08:47 PM
I am not expecting to see any of those for a while.......
Old 11-18-2018, 11:00 PM
primem's Avatar
primem
primem is offline
+1 what he said
the p0128 is a rationality code. the pcm monitors the coolant temp on a cold start up. It expects the coolant temp to be at a set number after a predetermined run time...if its not the code sets. so the fault is either with the thermostat being open or a temp sensor issue
Quick Reply: Code p0128
