driveshaft help!
driveshaft help!
Hey guys new here I am building a 1949 dodge wayfarer I put a 318 with a 4 speed problem I am haveing is the driveshaft on the rear its the smaller flange and the front has the larger flange from the trans is there a fix to this without cutting the driveshaft ?? will the larger housing fit on this shaft?? I would appreciate any input thanks Larry
