i'm trying to install a 440 w/ 727
66 coronet replacing 318 with 440 and 727, I got the hard motor mounts on line but they don't seem to be long enough my chassis mount holes are 14.5 inches apart on the chassis , the mounting hole for lower rubber mount is 1 inch lower than the 318 mounts but the spread is still about 1.5 inches to wide to fit properly mu question is there an even longer hard mount , it seems that if it were longer and the rubber mount hole was 1-2 in. lower that my chassis holes would line up. Any help out there would be helpful , Thanks
Moderator should move this, Does the 440 have the motor mount brackets? You cant use the ones on the 318 they are to short.
http://store.440source.com/Engine-Su...fo/119%2D1000/
