P0113 Code
Hey guys I have a 2015 dart and I have been having trouble with it wanting to stall out on me. The code P0113 keeps showing so I just replaced the Intake air temperature sensor, but the car is still acting the same and code is still there. Need some advise on what this could be.
Did you clear the code after replacing the IAT? No warranty left?
A code P0113 may mean that one or more of the following has happened: Internally failed IAT sensor Faulty connection at IAT sensor Open in IAT ground circuit or signal circuit Short to voltage in IAT signal circuit or reference circuit IAT harness and/or wiring routed too close to high-voltage wiring (e.g. alternator, spark plug cables, etc.) Faulty PCM (less likely but not impossible So if you replaced the sensor and the code did not clear, start checking connections and wiring. |
Code p0113
I am also getting the same error code. But my 2015 dart will not start and code is permanent. Can any tell me how to remove it?
Originally Posted by Anthony Elizalde
(Post 3495240)
Originally Posted by Capt. Derek
(Post 3495794)
That's really subjective there keaton
