Belt sqeaking bad
Belt sqeaking bad
Ok so i have been trying to solve this problem for quite some time now, my alternator belt is squeaking and i dont know why. If I spray wd40 on it or something, it will go away for a little bit, and then return like 5 minutes after im driving, if i spray brakleen on it to remove the greece it squeaks even worse. i replaced the belt yesterday thinking that was the problem, and at first i thought i solved it, but it came back today and its just as bad! when i put the belt on i noticed that the belt was off the water pump pulley by barely even a millimeter i dunno if that anything to do with it but it looks like that side is worn down already i can see white threads coming out of that side. if anytbody could fix my problem i would appreciate it greatly!
