92 dodge daytona Turn Signal Problems
Hey all, so I recently bought this car and i thought i could fix the turn signal issue. It turns out that I might have bitten off more than i could chew as I have had both hazards and turn signal lights failing to work, yet I can get power to the headlights and to the parking lights just fine. So far to fix this issue i have;
-Replaced the instrument panel with the control switch pod to insure it's not an issue there
-replaced the four fuse relays on the kickback drive side fuse bank that is hidden up and under the dashboard and the main fuse box.
-found the diode package fuse #11 that I think needs replaced, yet i have had a dickens of a time trying to find one to replace it.
Not only that, but I think I rewired or something wrong because now my normal headlights wont work after I replaced the instrument panel with the new one.
refer to this:
http://www.turbododge.com/forums/f4/...-90-93-ag.html
if you need any parts for this I have them but 1st figure out what you really need
these things are a can of worms and many things can go wrong with them!!!
