View Full Version : Dodge Journey
- Temperature control
- 2015 Journey Limited Battery Drain
- Wiring harness behind rear tow hook plug
- Wiring boot
- Front/Rear Windshield Washer Pump Not Working
- 2019 Journey value package question-Bluetooth
- 2016 sxt ac resistor location?
- 2012 dodge journey Locks not working properly
- Key FOB Programming
- Dodge Journey Mods
- Journey Battery Drain
- Battery ,after replacement
- Journey rear camber
- Journey grille guard
- 2016 Journey lift gate
- Radio swap
- 09 journey brake lights won’t go off!
- what sensor is this?
- No front passenger storage bin
- P06da code
- 2009 Dodge Journey
- Uconnect
- Odd vibrations
- How to release pressure fuel line
- alarm issues2009joueney HELP
- Dodge Journey - worst vehicle every made? Or worse dealership training?
- 2015 DJ Possessed??
- How to reset Uconnect on 2013 Journey R/T?
- Ball Joint Torque Specs for 2016 Dodge Journey
- No Air Coming Through Dashboard Only Defrost and Feet Help!
- Radio and controls lock up
- Does the WIN module also control the keyless entry?
- Is heat shield removal on 2012 dodge journey ok??
- 2013 journey radio display not working
- Electrical Problem
- Hello everyone, what is the nut size for negative jumping terminal post?
- 2009 Journey
- Leaking somewhere
- Reverse light wire configuration
- Coolant leak
- 2012 Dodge Journey rear blend door
- Aftermarket Bluetooth Recommendations
- No crank no start
- Frustrated with my 09 journey
- Engine Light won't go away... it just WON'T!!
- Turn signals
- 2013 Dodge Journey R/T SD card mp3 player displays track info inconsistently
- Steering wheel controls stopped working
- Rear window defroster
- 2012 Dodge Journey FWD rack and pinion replacement
- 2010 Dodge Journey RT-Possessed?
- Door Latch Stuck in Closed Position with Door Open
- Gearbox auto to manual---- i need help people
- Clicking from under dash passenger side
- Radio changing by itself
- No heat in rear 2015 Dodge Journey
- Wet floorboards after rain
- Headlight lens
- P306 miss fire
- overheating
- 2015 Journey bad idle no codes showing
- VIN on BLOCK
- 2012 Dodge journey reverse issue
- 2009 Dodge Journey r/t EGR issues
- 2018 Dodge Journey GT on the beach?
- Window Issue
- 3.6L 2012 Dodge Journey Crankshaft sensor
- Headrest activated
- My 2009 Dodge Journey SXT is JUNK!!
- 2011 Dodge Journey Losing All Power, Steering, Assisted Brakes
- Vehicle dying
- Uconnect problems
- 2010 Journey not blend door actuator
- 2017 Dodge Journey GT
- Uconnect Bluetooth Stops after 3 restarts
- 2019 journey no drill front plate braket
- 2010 Dodge journey driver side switch does not work except back windows
- Help with 2010 journey dash removal
- Hands Free loading and loading
- 2012 Dodge Journey R/T - Bluetooth module - expensive!!
- SELLING 2009 dodge journey $2500
- Oil in coolant
- starter stays engaged
- '15 origional Tires replaced causing humming sound
- Backup camera not working
- 2015 Crank Sensor
- 2017 Journey - Wipers Driving Me Crazy
- 2010 sxt - mtv circuit engine code
- Witch actuator
- Passenger side caliper
- 2012 Dodge Journey - Shudder in Rear End When Turning?
- Passenger Blend Door Actuator
- 2009 Journey - no turn signals when using column stalk
- If one actuator doesn't work, will it effect another one
- dash shows hatch open but it is closed
- Looking for part number for air filter housing clip
- Dodge Journey 2010 2.7L cant find 2.7L headgasket KIT!?
- journey 2015 climatisation
- 2012 Journey AC doesn't work on passenger side.
- 2012 Journy back hatch wont open
- BCM or Instrument cluster bad??
- 2010 Journey rear door
- dodge jurney 09r TCM module
- Rear Defrost Light Comes On When I Start My Car
- XM radio says "No signal See Dealer"
- Dodge Journey rt 2012 Rear Door Belt Outer Weatherstrip
- Brake Fluid Flush???
- 2016 journey ac low pressure port location
- serpentine belt cut in half
- Transmission problems
- Fuel filter location
- 2018 Journey Crossroad w/V6 - Oil Pressure
- 2009 Will start but not stay running
- 2018 Dodge Journey Crossroad Door lock problem
- 2012 Dodge Journey 3.6 Firing Order
- Need help on 2010 journey axel seal
- Blank Screen 2012 Journey
- 2012 Journey R/T etc light on won't start
- 2009 Dodge Journey wont start.
- Journey
- Journey ticking
- 2010 Journey R/T replacing automatic transmission output shaft seal
- 2010 Journey Dead Battery/Horn Beeping Repeatedly
- Journey 2013 SXT 3.6 U connect HFM (bluetooth) module issues
- 2009 Dodge Journey SXT 3.5L - Knock Sensor Location?
- 2010 Journey Shifter Issues
- backup camera
- Running a dedicated power line
- 2013 Dodge Journey R/T AWD issues
- Dodge Journey 2010 Horn, battery & warning lights
- Overheating inside the cabin
- Journey2010 RT battery drain continues
- 225/55R19 Tires Recommendations
- Infinity Amp Location in a 2010 Dodge Journey R/T
- A/C Clutch issues
- P0430, cat or o2 sensors that are faulty?
- ABS sensor clip removal 2015 Journey Front Driver side
- 2012 SXT - Optical CD Drive Making Noise Without Any Disc Inside
- my Journey navigation not work It’s show error can’t unlock maps
- CAT Delete
- Pinout cluster to power up
- 2019 Journey
- Transmission overfill
- Dodge Journey issues with Bluetooth
- 2014 dodge journey cel p06dd
- 2009 dodge journey sxt 3.5 // leaking fluid
- 2010 Journey wont start after running
- 2014 Dodge Journey SXT oil pressure sensor location
- 2011 dodge journey command start not working
- Dodge Journey Junction Block
- Dodge Journey 2009 won’t lock
- Multiple issues!!!
- 2012 Dodge Journey Parking Assist Sensor Fail
- 2013 Journey - Replacement Fog Light and Head Lights Blubs
- 2010 journey right tail light always on.
- Electrical nightmare
- 2.4L turbo journey
- doors fit to Journey 2015
- Dodge Journey 2009 problems.
- Dodge Journey SXT 2010 2.0 CRD Diesel - DMF
- No heat on passenger or rear of vehicle, warm air on driver side
- Navigation no detailed map
- Changing Subframe
- Dodge journey vacuum line
- No Rear heat air blowing
- battery
- 2011 dodge Journey no heat on passenger side
- 2012 journey crew fwd rear rotor size???
- 2010 Dodge Journey Blend Door Actuator
- 2017 Dodge Journey Headlights
- rough idle
- Uconnect, USB and rear camera faulty on 2013 R/T rallye
- Hello dears!!! help out-can who faced? DODGE NITRO when turning,, even at low speeds,
- Dip stick for transmision
- Passenger and rear door locks not responding to unlock
- Rear upper control arm bushing.
- Moonroof drains
- Journey Battery drain
- Won't start - Key Undetected
- Change in tire size
- 2011 Dash removal
- Uconnect - heat issue/screen glitches
- Had cabin filter changed & now heat blowing cold on pass side, are these connected
- Fog Lights Relay supply from ignition wire
- 2017 Journey Fog Lights
- Drumming noise at highway speed
- Heat
- 2011 Journey instrument panel freakish behavior.
- Oil pressure sensor location 3.5
- 2012 dodge journey 3.6 l, high temp readings
- Engine Shuts Off
- 19" wheels to 17" wheels
- Dodge Journey - Misfire and Parasatic Battery Drain
- Dodge Journey 2010 Diesel A/T, Cruise software updates?
- body control module
- Running wires through Firewall
- p0456
- my said is not ucnnect available
- Dodge Journey 2010 Diesel - Parking heater installation
- Uconnect stopped working
- AC condensate dripping from bottom of blower housing.
- ETC Light
- Does anyone have a CTP11, CTP12, or CTP12.5 firmware
- 2010 Dodge Journey rear air issues
- Uconnect won't connect
- Intermittent backup Camera
- 2011 3.6l cranks but won't fire
- horn going off by itself
- Neutral Safety Switch
- Air is stuck on floor vents
- Journey DEad Battery Syndrome
- Dodge Journey 2009 Diagnostic Starter
- Interior lights
- dome light stays on while driving
- Horn beeping randomly
- my car is actually posessed
- Battery Drain 2015 Journey
- which panel closeout
- Can you take an RB5 unit from any FCA
- Cranks but no start
- Rear wiper stopped working
- Preferred option group 28X and 2DX
- 2009 Dodge Journey 3.5 FWD break caliper issue
- Horn and emergency lights acting crazy
- Rear view camera
- why is my horn honking
- Fuel gauge not moving
- 2009 Journey Radio issues
- 2012 dodge journey 3.6 sxt
- remote keyless entry with remote start
- I believe dealer ripped me off
- 2012 journey
- Help my journey on it's journey
- Wierd location to find brake fluid.
- 2012 Journey RT
- 2012 journey
- Ladder racks
- tail lights 2015 journey
- 2010 journey
- Help!! Anyone know the axle nut size
- Bad Transmission Pump
- Overheating
- Journey
- 2013 Journey Uconnect update hell
- Front breaks locking on
- Wiper switch on 2009 Journey
- My engine problems still not solved
- Back up Cam
- 2012 Journey not shifting out of first
