View Full Version : Dodge Journey
- Rear AC Making Thumping Sounds when i unlock the door
- Bunch lil things 2010 journey
- Can't transfer music from USB to HDD
- Entertainment system constantly restarting
- Ambient air sensor location and wire
- 15 Journey Dashboard removal! DESPERATELY SEEKING SOME HELP!
- Aggravated, horn issue
- 2013 Journey SXT power door locks issue
- uconnect not working
- Plastic engine cover 2017 Journey
- Tire Pressure Service Warning!
- Ambient Air Temperature Sensor LOCATION
- 2010 dodge journey headest replacement
- 2009 Journey horn not working
- Dodge Journey Wheel Lock
- HELP Ghost car!
- Roaring noise from rear end/check engine light
- Dodge Journey 2010 Horn issue
- 2013 Journey SXT UConnect problems.
- 2016 dodge journey radio issue
- DOdge JOurney 2009 stuck drivers door - OEM for latch
- Thinking on getting a 2012 Journey
- Journey Hatch wont open!
- 2013 AWD V6 Journey Overheating issue.
- 2017 Dodge Journey GT Strange Noise
- battery keeps going flat overnight
- 2010 Journey 2.4 litre - Intermittent starting problem
- Trans fluid temp
- GPS not working
- 2017 Journey honkd everytime I open the driver or front passenger door
- 2012 journey 3.6 rt erratic gauges,loss of power
- 2010 Dodge Journey with honking issue
- 2010 Journey whining sound when turning
- 2009 dodge journey
- Added a new Microphone
- Dashboard
- Dodge Journey GPS Install
- Need Help Identifying Part
- dodge 2015 journey
- uconnect satellite radio for 2015 journey rt
- 09 dodge journey sxt coolant leak from engine
- 2015 dodge journey rt
- phone button not working
- 2012 Dodge Journey RT (Australia) rear aircon/heater not blowing
- Blackberry uconnect
- P0430 check engine lite
- 2014 Dodge Journey SXT 6 cylinders Loss of horse power
- cramshaft and camshaft
- Transmission
- oil pressure fluctuation
- Considering purchasing a 2012 Journey
- Instrument cluster replacement 2009 Journey
- Fan speed switch
- aftermarket back up camera
- Gas smell issues 2016 Dodge Journey
- No bluetooth - aux post new battery
- Back up camera
- Journey pulls to one side - need some troubleshooting tips
- frozen
- Electronic Throttle Control warranty for 2012 Journey
- Frozen in Michigan
- 2013 Journey, 6 cylinder, engine coolant temp sensor
- Interior Lights and Door Locks 2009 Dodge Journey SE
- 2009 Journey SXT heater core
- Radiator fan running
- Replaced battery, remote start no longer works
- Journey Ambient Air Sensor
- Fan speed not working properly
- 2014 Journey CD/Dvd Player Issue
- 2010 Journey engine light
- 2010 Dodge Journey Dome Light
- oil pan replacement
- 2010 journey horn and steering wheel control not working
- bluetooth/usb connectivity
- 2009 SXT - Radio works but no display
- 2009 Journey Temperature problems
- '16 journey R/T back up camera and navigation upgrade?
- 2010 Dodge journey coolant flush
- 2013 Dodge Journey SXT - uConnect 8.4 Firmware Upgrade
- 2010 Dodge Journey not starting
- Wireless Back Up Cam - 4.3" UConnect
- Uconnect and bluetooth connections
- Horn Going Off by Itself
- 2010 journey oil control valves
- Humidity on air filter box
- Leaking Dodge Journey 2016 v6
- Caliper issues
- Oil pressure switch again
- Dead battery
- 2009 Journey 2.4L - Intake Manifold Runner Control
- 2013 Dodge Journey locks acting up
- 2009 4cyl Journey starter install
- Driver side tail light on lift gate not getting power
- 2009 Dodge Journey: Dinging & Won't Start
- Dodge Journey
- 2010 panel covering rear AC
- What happen to the "Chrysler Wiring Diagrams (English)" site?
- Move Rearview Mirror
- how to reassemble these
- Need 2016 8.4 Wire Diagram
- shift cable replacement
- 2012 Dodge Journey Crew
- 2009 Dodge Journey A/C problems
- Journey - Battery Drain Overnight - Rear HVAC
- 2010 journey..bypass nuetral safety switch
- 2014 dodge journey 2.4l fan not turning on?
- 2012 Dodge Journey HFM Hands Free Module
- Coolant water
- 2010 Journey ESP/BAS, ABS and 2 Other alarm
- 2010 Dodge Journey Ambient Air Temperature Sensor
- Ambient air sensor location?
- Airbag Light ON!
- 2016 dodge journey-upgrade the 4.3 radio?
- 2011 journey crew radio no power
- 2010 journey 2.4L exhaust issue
- Door Will Not Open! Help
- Active head rest help.
- OBD nightmare - please help
- Is it Possible
- 2011 Journey: How to remove base of Satellite Antennae
- 2013 journey won't start
- DIY Journey tranny dipstick project
- 2011 Journey Satellite Antenae Replacement
- Unable to hear audio on hands free system
- Driver side head light
- Coolant temp in 2014 journey
- USB ports no longer work and phone stuck on "Loading"
- Short battery life with key fob?
- Backup light wire identification
- Rear Storage Bin Liner
- Shifter
- 2015 Dodge Journey Turbo
- Music on hard drive
- 2012 journey engine problems
- Rear View Camera Problems
- Maintenance and Repair Guides
- Wheel size question on 2015 SXT
- 2015 Dodge Journey Crossroad- DTE Gas
- Journey 2009 Weird Braking Problem
- Horn-beeps-3-times-and-doors-unlock
- Dodge journey - replace rear struts
- 2010 Journey window ghost
- Journey Wheel Size?
- RE2 to RB5 Nav upgrade not working, dealer is no help
- Transmission issues!!!
- 2013 Journey - Key fob Intermittent Response?
- Lost Key 2015 Dodge Journey
- Help this idiot out
- 2010 Dodge Journey SXT 3.5L A/C Compressor Replacement
- 2012 Journey (and dealership) NIGHTMARE!
- Electrical Issues ???
- New Member Needs New Rubber...
- 2010 - Passenger Door won't open from Outside
- 2011 Journey noise left turn
- Satellite Radio not working
- New Member
- 09 Journey Drive Belt Tensioner 3.5L
- Back Up Camera - 2012 Journey Crew
- Really disappointed in Dodge
- Intro from a new member....
- engine trouble code
- Tire wear on 2015 Journey SXT model
- Turn signal on a 2010 Dodge
- AC condenser broken - Compressor at risk?
- 12 dodge Journey Crew CC
- Broken wires
- Side mirror fall off (because of calcium maybe)????
- 2010 journey ac problem
- Remove Sunroof switch?
- Hesitation and miss
- Coolant leak
- 2013 Journey with noisy strut
- 2010 Dodge Journey SXT overheating...
- 2011 Journey RT AWD needs some TLC
- 2014 Dodge Journey V6 Fuel Economy HORRIBLE
- HELP! Journey 2.0 CRD RT stalling at high RPM
- 2009 Journey Cooling System Hose Size
- 2012 Journey Car door sensor
- 2012 journey no display, radio, a/c or speedometer
- 2012 Shift knob
- 2010 Journey AC question
- bezel plate cover removal
- Where to find black grille for '13 SXT?
- I want to lock the key fobs in the car (yes that's right)
- A/c
- Help Journey 3.5 v6 starter replacement
- Dash dark
- use R-416a for aircon hiss
- 2015 journey crossroad side view mirror replacement
- rear bumper replace 2013 journey crew
- Dodge Journey brake upgrade
- Another rookie question...
- In need of torque specs
- 2012 Journey SXT ABS/Traction control light is on.
- High pitch frequency/grinding when accelerating with my 2010 Dodge Journey
- Sourcing oem parts
- front passenger water leak above door
- Front and Back Sensors for DJ '09 with signals in MyGig display?
- 2013 Journey A/C question
- Shifting/high engine rev help please
- engine code p1005 and p2078
- Fault Code
- New to the forum. Need some feedback about 2015 Dodge Journey
- Syncing Phone book on a MyGig REU/REX
- 2014 Journey driver's seat shield
- Journey randomly doesn't start...Bug with the "smart key" ?
- 2013 Journey 2.4L, I need some more acceleration.
- Add reverse cam & nav to 2011??
- journey sxt 3.6
- 2015 Journey $3000 off MSRP, $18613. Could I get more discount?
- 2013 Journey Flicker of lights while car is off
- Armored DJ - Gear not shifting when heated, they want USD 4,000 to fix it!
- catalytic converter 09 dodge jounery
- map upgrade for 2010 journey
- How to clean the platinum chrome accents on Journey Crossroad
- p0760
- I need help
- Hub assembly
- security system alarm
- how to install back Camera in Journey SXT 2014
- Oil filter for Journey sxt 2014
- Little black box
- 2013 Dodge Journey-Passenger Door not closing properly
- diy brake job
- Help! Is KitKat Too Sweet For Uconnect?
- Auto Comfort-On not working
- Sirius XM problems
- Just purchased a Journey
- 09 journey turn sigal issue...
- keyless entry
- No Heat on Passenger Side
- Sunroof Leak
- Question about aftermarket car alarm install on '09 Journey
- Hello I am new here , my name is Jae Matthews and I really need help A.S.A.P
- 2012 Dodge Journey help needed A.S.A.P
- 2012 Dodge Journey AWD SXT
- Dodge journey 2012 signal light
- 2011 journey wont start
- code 0128
- window motor
- Cold Starting
- L25 Recall ??
- 2009 Journey code P0430
- help 2010 journey
- iPod won't play
- 2015 Dodge Crossroads Fluid Temps
- 2015 Journey Crossroad
- 2015 Dodge Journey security alarm sensitivity question
- menu engineering
