View Full Version : 2nd Gen Neon
- replacing timing belt, torque struts
- A/C Clutch Not Receiving Power
- A/C Clutch location?
- '04 Neon ground effects
- Constant Volosity shaft or pinoin bearing? Video
- This may be a stupid question, but...
- Radio connection question, '01 Neon
- Programming RKE with a jumper??
- iac valve
- Never done a Half shaft replacement. NEED Help.
- Radiator fan kicks on before getting to temp?
- 2003 dodge neon sx2.0
- 2003 Neon SXt trunk lid adjustment
- belt tensioner pully
- 2000 dodge neon overcooling
- 2002 neon wont start
- "Cruise Shift Points"
- Slow communication thru DLC
- Tailights taking on water?
- oil burning, soon to be a lifter tappin, clakity klack
- Idle Help w codes
- rims and tired
- Can't dim headlights while driving
- Liquid leaking on passenger side
- oil pan
- Valve cover question
- Help with my 05 Neon
- 01 dodge neon
- Belts for under drive pulley
- 2002 dodge neon
- HID Lights
- Please help!!
- 2000 Neon - Please help!!
- Fuel Probem or not?
- rack question
- Vibration Noise on Neon 2000
- whinning/whirring noise at 55mph
- 2004 neon heat
- 02 Neon in limp mode, P0700, P0755
- rally car clone
- SOHC help
- Intake and rocker arm shafts?
- Aftermarket Throttle Body
- Charging issues
- need answers about 2003 Neon
- Here is one for the neon gurus
- Got my PT Clutch Today
- cold air intake
- 2002 Neon - need part numbers and ID
- 2005 Dodge Neon Engine Issues
- Hub Nut
- help having problems with my 05 head
- 2003 Exhaust Manifold Heat Shield bolt question
- wont start after used head and cam, no codes
- P0441
- 2004 Dodge neon sxt - convert to a srt-4? Help!?
- Coolant Alledgedly Came Out Tailpipe
- Poor Fuel Economy
- Rear Brake assembly
- Clutch slipping
- Need help!! Noise in rear!
- 2000 neon es 2.4 swap
- 2004 neon not charging
- Transmission compatibility
- Front center ehgine mount R&R with video
- Need PDF owners manual 2002 Dodge Neon SXT
- Brake fluid flush or tip off?
- 2002 Neon RT
- OEM Mopar Center Engine Mount....look inside
- Mad Max is dead.
- Broke PCV off in valve cover
- 04 SXT Engine Mounts....thoughts inside
- 2004 Neon 116k miles Misfire at high RPM
- I bought MOOG sway bar bracket bushings
- fuel cap help
- Sold my Neon
- Heater not blowing any air!!!!
- center motor mount bolts were loose..
- 2000 neon 3 & 4 no spark
- codes pop up
- help ps pump
- Motor Mounts
- top motor mount passenger side
- turn the key nothing turn again it starts
- Code P455
- codes 0442 and 0171an 1648
- good injector, always stuck on
- IAC Valve Gasket?
- heater blowing warm air
- Anchor 2975 tranny mount
- Drove through water and neon quit
- oopps.. dropped timing cover plug inside timing cover..
- 2005 neon sxt possible transmission problem
- Nubie ?
- Looking to turbo a 2.0 2000 dodge neon motor
- What are my best options for best performance
- head leakin oil
- bought a neon
- buying 01 neon
- Transmission HELP!!
- Cam position sensor P0340 need help
- going to switch to synthetic oil
- Need some help
- Advice on parting out or keeping
- codes after a trans rebuild
- ignition coil pack and wire set...
- No heat, 2004 SXT
- did a compression test today..
- darth roush tune up
- level kit
- shopping for a neon at dealership
- water pump inlet tube
- buying parts
- 2004 Dodge Neon R/T transmission problems.
- buying a neon from owner
- cooling system pressure cap neck
- getting good gas milage agian...
- 01 neon fog lights
- Last motor mount...
- to vinyl wrap or not to vinyl wrap?
- finally made my short ram air box mod
- iac stuck
- 02 Neon Hesitating in Reverse when it's cold
- Front struts, and strut mounts
- strut tower mount bar
- Pvc-puddle
- Rough Idle and/or Steering Wheel Vibration
- Tranny swap
- Cylinder Head Cost????
- wierd CLUSTER shuts down--->
- 2001 neon blows fuse # 21
- 2000 neon
- no more piston slap---->>
- 2004 dodge neon sxt vibration
- new fuel pressure regulator -buzzing-???
- Ideas For a project srt 4
- Intermittant starting problem.
- Recent Oil Change Service - now studders on accelaration..?
- 04 Neon not firing on 1&4, 2&3 good
- Studder on accel, while at stop in Drive/Reverse
- 2005 sxt -front & rear strut replacement
- PT Clutch
- Need Service Manual for 2002 Neon
- Need picture to compare please.
- NEW Catalytic converter! VIDEO-->
- motor mounts intallation
- Play nice everyone!
- parts bin question
- Spoiler
- HELP... I need a crankshaft
- 03 Neon- Heater Hose Inlet/Outlet Pipes
- Brake pedal bounces
- New Catalytic converter installed!
- ac evaporator core
- 2001 Dodge Neon - PCM
- Carbon fiber
- timing belt / water pump question
- 2002 Dodge Neon Stereo shutting off, volume not working...
- 2003 dodge neon acceleration problems
- Oil filter wrench size
- New headlamp housing
- Filter with pics
- My front brakes
- should I just do this?
- rear struts brake cable in my way
- 03 Neon Engine Mounts (source?)
- 03 Neon- Which Frt Suspension parts to replace?
- No fuel pressure in uneven surface
- stock hood modified to look like srt 4
- battery post connector
- 03 Neon Cam Position Sensor replaced. Still not starting, help!
- Cold tail pipe.. -->>
- Power Steering Troubleshooting Help Needed
- automatic tranny shifter knob
- Clutch hydraulics & grinding shifts
- p0344 engine code
- Old member, newb question
- The Official 2nd Gen Neon Off-Topic Thread
- Battery/Charging Issues
- Intake manifold
- 2003 Dodge Neon SXT Idle Problem
- evap emission
- Hahn turbo info?????
- titanium header wrap --->
- 15" Rims
- 2000 neon
- Need some help with 2005 NEON
- found solution to steering wheel shake!!
- keep blowing DRL fuse, Please Help!
- 2000 neon exhaust manifold cracked
- Neon Brake Problem
- P0740
- Cluster swap
- Advice on what I need to do?
- 2000 neon coolant smells outside.
- Heavy /Stiff Steering
- 05 sxt tranny swap
- 03 Neon SXT- Engine Rebuild/Replace Questions
- stupid trunk opening issue
- 05 better throttle response i guess?
- Front end damage, advice?
- 2000 dodge neon 2n gen
- Fluid leak at solenoid pack , please help!!!
- Mopar Strut Mount vs aftermarket
- O2 sensor voltage high
- Intermittent stalling when starting
- Two codes please help
- P 0420 Again
- A little help please, My car died between an intersection today...
- 7 engine codes and a busted window
- Idle Problem
- Metal Piece fell off of car - what is it?
- 03 Se 4 speed auto tranny swap
- MOTOR swap questions..
- 2005 SXT Borla
- 2004 Neon sxt - listening to MP3/iPod
- Visors
- 2000 neon K FRAME
- P0441
- exhaust questions...
- Rear Main Seal or Oil pressure sending unit?
- Timing Belt AGGRAVATION!!!
- Strong fail on Modern Performance's Mount Inserts
- 2000 dodge neon power steering belt
- 2000 Neon JERKING.
- Questions for mechanic guys
- Black Dome Light
- intake and exhaust rocker arms -->>>
- Idle issues after TB cleaning
- 2 Brand New Mounts Installed
- How to remove the valve body
- Dodge sx2.0
- Timing issues
- 02 sensor swap? -->
- bad timming belt tensioner..video...-->>
- 05 neon stalls out every time
- BAD gas milage..agian..wtf..
- another Timing Belt question...
- Low idle after vehicle warmed up
- fuel filter...
- Radiator Fan troubleshooting
- P0340 error code
- Exterior Door/Window molding... What is it called / part#?
- Cleaning my car.. found a busted ground wire.
- 2002 dodge neon help
- Cel: P0344 & p0123
- HELP with Catalytic converter
- Parking lights
- Power outlet not working
- air box question
