Notices
72 360 parts
Old Jul 10, 2008 | 01:19 AM
fox's Avatar
fox
Default 72 360 parts
I've got a bunch 72 360 and some 318 parts.
These parts came out of a 1972 Plymouth Fury III with 135,000mileswhich include:
Gasket Set: $10 +S&Hall gaskets except head gaskets, valve seals, and rear main seal.
Pair of heads, these have been tanked but need new guides and need to be resurfaced, these also come with the original valves which were still good but need new springs. $50+ shipping
Intake manifold: this has been tanked and bead blasted. $40 + S&H
Valve Covers: $10+ S&H
Pushrods $5 + S&H
Carb: Holley 2bbl needs some cleaning $50+S&H
Pistons and rods: all stock $20+ S&H
Crankshaft: Crank probley needs to be ground $20 +S&H
Timing cover: Been beadblasted $20+ S&H
Rocker arms: $10 + S&H
Oil Pan: Been tanked $20 +S&H
I also have a set of 93 dakota5.2 stock exhaust manifolds beensandblasted and high temp paint theseare suppose to have bigger exhaust ports than the 94-96 daks $20 + S&H
All parts are sold as is.
Old Jul 10, 2008 | 04:12 PM
jlamaster's Avatar
jlamaster
Junior Member
Default RE: 72 360 parts
is the intake a 2bbl or 4bbl?
Old Jul 10, 2008 | 06:42 PM
fox's Avatar
fox
2bbl
Old Jul 10, 2008 | 07:03 PM
jlamaster's Avatar
jlamaster
Junior Member
thank you
