Notices
2000 Dodge Dakota R/T (IB /CC) for sale in treasure coast FL
Old Aug 10, 2008 | 09:37 PM
air_odie's Avatar
air_odie
Exclamation 2000 Dodge Dakota R/T (IB /CC) for sale in treasure coast FL
2000 INTENSE BLUE DODGE DAKOTA ROAD AND TRACK (R/T)
Mileage: 101,864 miles
Vehicle Information
VIN: 1B7GL22Z5YS516335
Warranty: Vehicle does NOT have an existing warranty
Vehicle title: Clear (most titles)
Condition: Used
Features
Body type: Pickup truck
Engine: 8 Cylinder
Exterior color: Blue
Transmission: Automatic
Fuel type: Gasoline
Interior color: Gray
Cab type (for trucks only): Extended cab
Safety features
Passenger & Driver airbag
Anti-lock brakes
Power Options
Air conditioning
Cruise control
Power locks
Power windows
Power seats
CONDITION:
This is a USED 2000 DODGE DAKOTA ROAD AND TRACK (R/T) -CLUB CAB
PHOTOS OF INTERIOR AND ENGINE -----------------------
http://s38.photobucket.com/albums/e1...%20sale%20two/
EXTERIOR AND OTHER ----------------------------------
http://s38.photobucket.com/albums/e1...20blue%20sale/
It has an INTENSE BLUE exterior featuring BLACK side mirrors and handles, and a BLACK spray in bed liner (NOT a cheap one either) The condition of the paint is it is starting to show some clear coat inconstancies, and has some scratches, nicks, and swirls in it. NONE are large and anything having to note has been photographed and shown.
It has an agate GRAY interior, which is in VERY good shape, SMOKE FREE and well taken care of. All upholstery, seats and carpeting has been shampooed recently and the interior detail has been very though as I prepped for the sale. It features a well-trimmed package as noted below. Items to note on the interior are, there is a small un-noticeable tear/burn on the rear split bench seat from an unknown source, the driver side power seat is missing a switch but still works fine (part on order), there is some small hazing on the rear plastic pieces where the previous owner improperly removed them. There are some signs that the truck has been used but the photos show what has to be said once again.
FEATURES:
Engine: 5.9 Liter (360CI) V-8 sequential-port fuel injected motor with fresh tune up at 100,000 miles including NEW Taylor 8mm wires, ACCELL cap/rotor, NEW 360 AIR INTAKE, New Spark plugs, Fully serviced fuel injection cleaning involving throttle body, fuel tank/fuel lines, and inspecting fuel tank/pump. MOTOR is VERY STRONG and is a PUSH-ROD V-8.
Transmission: 46RE, FULLY removed and REBUILT at 98,324 miles by AAMCO transmission, HAS A WARRANTY ON IT. REPLACED torque converter and added shift kit to rebuild as well. Automatic with OD. (Original transmission was losing main pump and II decided to completely over haul it) Is a RWD vehicle with ANTI-LOCK breaks and posi-traction
-----------COMFORT EQUIPMENT AND ACCESSORIES--------------
POWER STEERING POWER BREAKS
POWER DOOR LOCKS POWER WINDOWS
GAUGE CLUSTER TRIP ODOMETER
TACHOMETER AIR CONDITIONING (ICE COLD RECENTLY REDONE)
TILT STEERING WHEEL CRUISE CONTROL
TINTED GLASS DRIVER AND PASSENGER AIRBAGS
ELECTRIC SIDE MIRRORS UPGRADED UPHOLSTERY PACKAGE(R/T)
COURTESY LIGHTS/ILLUM PACKAGE DIGITAL INSTRUMENT DISPLAY
AUTO DOWN DRIVER WINDOW REMOTE DOOR ENTRY WITH PANIC
ANTI-LOCK BREAKING SYSTEM POWER ASSOC OUTLET
FRONT/REAR SHOULDER HARNESS REAR PRIVACY GLASS
------------------------------OTHER ACCESSORIES-----------------------
ALLOW WHEELS FUZION ZRI PERFORMANCE TIRES
CLOCK INTERVAL WIPERS/FRESH BLADES
FRONT BUCKET SEATS RECLINING SEATS
BODY SIDE MOLDINGS PACKAGE CUP HOLDERS (S)
CENTER COUNCIL LEATHER WRAP STEERING WHEEL
MAP LIGHTS CENTER ARM REST
REAR STEP BUMPER CURTIS HITCH
CARGO LAMP VENTED REAR WINDOWS
POSI TRACTION FULL R/T PACKAGE
SERVICE MANUAL ON CD THUNDERFORM SUBWOOFER BOX (UNLOADED)
HISTORY:
I purchased this vehicle on 08/20/2003 with 59,227 miles on it from ROSE CHRYSLER JEEP in WHITE LAKE, MI. I am the second owner and the previous owner did get in a front-end wreck as the car fax shows. The dealership repaired and repainted the entire vehicle as well as installed a bed liner and new tires as an agreement to my purchase. I paid just over 12,000 for the vehicle. I have a long and thick folder of parts and service receipts showing vehicle maintenance and just the fact that I took care and not just driven the vehicle. Some of the key parts are as follows:
14JAN04 63,339 miles replaced rear pinion seal under warranty
07JUL04 67,401 replaced ignition cable, relocated coil pack and had an electrical short fixed
19JAN05 75,448 FULLY serviced transmission at dealership
24MAY05 81,380 replaced all 4 tires with FUZION ZRI's
15SEP05 83,716 Serviced AC, full vehicle inspection
08NOV05 84,300 Flushed and replaced brake and power steering fluid, replaced power steering hoses
27JAN06 85,000 FULLY serviced transmission
19JUL06 88,985 Added hitch and serviced rear differential
10SEP07 98,334 Replaced transmission at AAMCO, also replaced torque converter and added a shift kit
12JAN08 99,997 had upper ball joints replaced under warranty and truck inspected
15JAN08 100,000 COMPLETE tune up, plugs,wires, cap, rotor, fuel service treatment, coolant flush, oil change, tire balance, front end alignment, belt tensioner check, several other checks.
14APR08 100,300 AC system was replaced at FIRESTONE
SINCE I PURCHASED THE TRUCK OIL HAS BEEN CHANGED IN 6000 MILE INCREMENTS USING MOBIL ONE OIL AND FILTER, TIRES ROTATED EVERY 12,000 MILES. ALL other services done as they came up or when due by MILEAGE/AGE
Vehicle issues
PAINT AND BODY- small marks, dings, etc...Some minor damage on passenger side in three spots
MECHANICAL- needs new shocks, and o2 sensor is 85% of life
INTERIOR- needs new sound system -I can install one easily for a good price
SHIPPING AND PAYMENT:
There are several shipping methods by other individuals that can be looked into; I will drive the vehicle to you anywhere in the state of FL or GA, for a reasonable fee,
Local pickup can be arranged and I can pick you up at the airport (MELBOURNE, FL closest, also WEST PALM BEACH (PBI) or Orlando (MCO).
OTHER SHIPPING METHODS CAN BE DISCUSSED
PRICE $ 4500 USD
AHH YES PAYMENT
Upon full payment, YOU WILL receive a clean title, bill of sale, vehicle as described, 2 sets of keys/key fobs, paperwork, receipts, and other vehicle documentation.
ACCEPTED PAYMENTS: MONEY ORDER, CASH, CERTIFIED CHECK FROM A NATIONAL BANK, or DIRECT DEPOSIT to my Wachovia or National City account(s)
ALL IN US FUNDS ONLY!!!!!!!
THIS VEHICLE IS FOR SALE AS IS WITH NO WARRANTIES IMPRESSED OR IMPLIED UNLESS UNDER WRITING AT A LATER DATE, I AM AN INDIVIDUAL SELLER SELLING THIS CLEAN TITLED VEHICLE MYSELF. MY INTENT IS TO SELL THIS VEHICLE HONESTLY AND FASTLY, AS I CURRENTLY DO NOT USE IT AND NEED TO USE THE SPACE FOR OTHER VEHICLES. ALL EFFORTS TO ACCURATELY SHOW, PORTRAY, AND EDUCATE YOU ON THIS VEHICLE WILL BE MADE!
THANKS FOR LOOKING, ANY QUESTIONS ASK!!!!!
JT
Last edited by air_odie; Oct 4, 2008 at 11:55 AM. Reason: changed price to 4,500 USD
Old Aug 17, 2008 | 11:42 AM
air_odie's Avatar
air_odie
added stock stereo and a carfax to the truck ad
Also price is somewhat NEGOTIABLE
Old Oct 4, 2008 | 11:55 AM
air_odie's Avatar
air_odie
PRICE DROP
4,500 usd OBO
Old Jan 15, 2009 | 03:44 PM
98DakotaFan's Avatar
98DakotaFan
is the truck up for sale or have you already sold it and would you be willing to trade.
