Notices
97 Dodge Ram 8" Skyjacker, 35's, 360, NICE
Old Mar 31, 2009 | 07:15 PM
shawngrace5's Avatar
shawngrace5
Default 97 Dodge Ram 8" Skyjacker, 35's, 360, NICE
97 Dodge Ram 1500 4x4
5.9L 360 Engine
140,000 Miles
SEE ATTACHED FOR PICS
8" SkyJacker Suspension Lift (NO BODY LIFTS)
35" Pro-Comp X-terrains on 17" IONS (New Last Summer)
Sony MP3 CD Player w/ 2 Kicker Subs and 350 Watt AMP
(could use a bigger amp)
Dual Exhaust- 3" Pipes with 4.5" Tips....IT ROARS
No Mufflers, CAT punched out.
Needs Transmission Work
(delayed shift points)
could just be a shift selonoid
or could need a rebuild.
It was always a good shifting transmission and all of a sudden started stay in first and second gear alot longer than its suppose to.
The engine has ported and polished heads with a mild cam
Its got a nice chop to it when it idles.
Complete MSD Ignition (From Plug Wires, Coil, and MSD 6AL Box)
4.56 Rear End Gear (have front 4.56, but needs installed)
Rear End was built last summer with 4.56 Gear
All High Performance Parts- built to handle over 750 horsepower
Cost me $800.
New Ball Joints, Tie Rods, U Joints, and Wheel Bearings
New Pro Comp Steering Stabilizer
New Radiator (old one was leaking)
New 180 deg. Thermostat
New Fuel Pump (just installed yesterday)
the other one was low on pressure
Front Differential is Leaking a little bit, I haven't fixed it lately
because I've been wanting to change out that front gear.
This truck has been my pride for the past two years, unfortunately my outlaw late model race car is top of my list and is why I am forced to let my truck go.
Last summer I got bored with the looks of the front end so I dropped ALOT of money into an LMC front end
Dual Ram Air Hood, Never seen another dodge with this hood! ($600)
LMC Chromed, Billett Front Grille ($250)
LMC Chrome Billett Grille Bumper ($500)
Chrome Upper Bumber Cover ($200)
Lower Bumper Cover Prof. Painted same color as truck, Very Neat
LMC Clear Headlights w/ Corner Lights ($250)
E-mail me for MORE PICTURES @ Gracsr01@ipfw.edu
Call Me @ (260) 350-2972
$4500, very firm on this.
I have over $10k in this truck, BAD *** TRUCK
After its all said and done I will kick myself in the *** for selling!
Transmissions are cheap to build if you know what your doing.
Transmissioncenter.net has a high performance re-build kit
for less than $400. Cant beat that.
