Notices
1998 Neon 5spd 2 dr DOHC -- $2200 My LOSS -- N. Idaho
Old Jun 25, 2009 | 07:45 PM
meaculpa3x's Avatar
meaculpa3x
Default 1998 Neon 5spd 2 dr DOHC -- $2200 My LOSS -- N. Idaho
1998 Neon 2 door. Has the DOHC engine. The transmission was just replaced with a used one that has only 46K miles on it. The engine and the rest of the car has just 101000 miles on it. Runs and drives excellently. This is a very reliable and great driving car. The "sport" model meaning no power locks or windows, cruise or tilt. Has factory driving lights. Interior is excellent. Tires all matching and 70%.
The following was all NEW in the last three months... Totals over $2000 in parts and fixes, my loss is your gain!!
All 4 struts brand new KYB's
Head rebuilt & new head gasket
Timing belt
New Radiator
Double platinum spark plugs
High performance plug wires
Cold air intake
Throttle position sensor
Idle air control valve
New clutch, pressure plate, flywheel, throw out and pilot bearings
Output shaft seals
Shaffers differential and engine oils
Front brakes
Rally style projection headlights
Euro turn signal and tail lights
Front and rear strut braces
White face gauge kit
$2200 Call Scott at 208-687-6871 or 208-964-6804 if you are interested
The car is located in North Idaho. You can come pick it up or I can ship it to you at your expense.
