Notices
1985 Dodge Pulling Truck in WV
Old Sep 13, 2009 | 03:24 PM
mprldy's Avatar
mprldy
Default 1985 Dodge Pulling Truck in WV
SOLD SOLD SOLD
Posting for my neighbor, but it's being stored in my garage:
NEW PROFESSIONALLY BUILT 541 CU.IN. MOTOR.WORLD PRODUCT MOPAR BLOCK, INDY TOP END,BEST OF EVERYTHING!!!! A&A BUILT TRANS,4.88 GEARS, DANA 60 FRONT WITH DETROIT LOCKER, RA 20 REAR, NEW MOTOR,TRANS,TIRES,MAGNAFUEL FUEL SYSTEM, HYDRAULIC STEERING,856 HP, 760 TRQ., 25,000.00 IN MOTOR ALONE. DYNO TIME AND 3 PULLS ONLY ON MOTOR, 2 1ST PLACES AND 1 3RD PLACE. TRUCK HOOKS GREAT NO ISSUES! MUST SELL BUYING HOUSE, ALL OFFERS WILL BE CONSIDERED. WILL SELL TURN KEY FOR $16,000.00 OR SELL MOTOR FOR $12,000.00, MOTOR AND TRANS FOR $14,000.00. CALL (304)830-2889 FOR MORE INFO or email me at cdurig@hotmail.com or moparlady11@verizon.net for pictures .
here's a partial list of the motor goodies:
NEW 541" MOPAR, WORLD PRODUCT BLOCK, CAST IRON 440-1 INDY HEADS FULL CNC AND PORT, INDY INTAKE PORT AND POLISHED, JE CUSTOM FORGED PISTONS, EAGLE 4340 STEEL RODS W/ARP L19 BOLT UPGRADE 7.100 LONG .990 S.E., EAGLE 4340 STEEL CRANK, 4.375 BORE, 4.500 STROKE, COMP CAMS OFFSET ROLLER LIFTERS, COMP CAMS CUSTOM STEEL BILLET ROLLER CAM, COMP CAMS ADJ. BILLET TIMING SET, ARP HEAD STUDS, ARP OIL PAN STUDS, ARP STAINLESS INTAKE BOLTS, VALVE COVER STUDS, AND EXHAUST STUDS. MILIDON OIL PAN AND WINDAGE TRAY, MILIDON ADJ. OIL PRESSURE REGULATOR KIT, EXTERNAL OILING, MSD PRO BILLET DIST. AND WIRES, EDELBROCK ALUMINUM WATER PUMP, BILLET PULLEYS, CLEVITE MAIN AND ROD BEARINGS, 14.3-1 COMPRESSION, O-RINGED BLOCK, APD 1000 CFM CARB, 3 RING ATI BALANCER, MADE 856 HP AND 776 TRQ. ON DYNO. PROFESSIONALLY BUILT WITH ALL DOCUMENTS AND DYNO SHEETS.
