Cured ping issue on Diablo tune!
All I did was add more fuel. 7.5% to be exact. Not only did it stop pinging but it pulls alot harder too! So if anyone is having ping issues try it.
Thanks man! Yeah they havent fixed that yet. But since I raised the rev limiter 600rpms which is the max, I can manually shift at 6k rpms now.
Last edited by M15; Dec 2, 2009 at 02:08 AM. Reason: wanted to add in a couple of words
I tried up to 10% across the board and it appeared to be fixed and then MDS would kick in causing the knock to jump to around 10. I broke down and purchased the Mike Wilson tune and hope the problem goes away.
Diablo forums are not very helpful, because I have no problems when running stock the most I would see is maybe the occasional 3 with no fuel retard, even when MDS kicks on.
