09 Dodge Ram Wheel Swap
I got some 17" wheels/rims to replace the ones on my 2009 Ram that I don't like so much. I'm pretty sure they came off of an 08/09 Durango. Does anyone know if I'll have a problem with these? As long as the bolt pattern is the same I was thinking I would be ok. Thanks.
If the bolt pattern is the same, the wheels should fit fine. Are the tires the same size as what's on your truck or are you going to switch them over? The tire pressure sensors would probably need to be switched over too.
Edit: Though it's probably fine, you ought to double check to make sure the offset if fine too. Being that it's a pretty new dodge wheel, I would bet that it is.
I'm probably going to put new tires on the wheels, doing the pricing game now on some 285/70/17 BFG AT's.
The TPMS things are still mounted inside the wheels that I want to swap to. What are the chances that they will be calibrated/set to the right psi so I don't have to pay to have the TPMS things swapped from the old wheels to the replacements.
That's ignorant that those things would be made to where they can't be calibrated. It would be nice if they were the same default though. Anybody know the psi settings for the Durangos?
