Towing help
Hey guys,
I'm moving to Florida next month and I'm planning on pulling a uhaul trailer behind my truck. At most it should be about 5000 pounds. My truck has the tow package with 3.55 gears and I'm pretty sure it doesn't have the trans cooler. Should I be worried or should I go ahead and install one anyways? Thanks!
A trans cooler is alwaya a great idea, it will keep the temps what ever they maybe to less than what it normally would be, just good insurance, the 3:55"s will pull that weight with NO problem at all . Depending oin the tongur weight, you may want to look into a set of air bags for the rear, but they are not required, it handles the load better , and when you are done pulling can be deflated to give you back your ride, best of both worlds.
Regarding my 3.55 Open Diff I plan to keep the 3.55's because I like the gas mileage (A little better than my 2006 2WD with 20's and 3.92) but I do plan to put in either a DTT or Auburn LSD for christmas.
Yea I'm going from Camp Lagoon to MacDill AFB, Tampa, FL. I'm pretty much taking 95 the entire way.
Trending Topics
Dude, you will be fine.
A uhaul that can be loaded that heavy will have built in surge brakes... essentially the tongue can slide back and forth slightly and it has a master cylinder built into it. When you hit your brakes your truck slows down, but the trailer tries to keep going. This causes the tongue to slide back engaging the master cylinder that engages the brakes that makes the trailer slow down until there is a balance between the force being applied to the tongue by you slowing, and the force being applied by the breaks at the behest of the tongue... Buying a TBC is pointless: no interface on the trailer (I am on a "sabatical" from uhaul).
5k lbs is not a bad haul... honestly unless you get sway or a bad crosswind you will hardly notice it.
