LT 275x65 R20
Any one running these with pics? Did a quick search but no luck. I think they should work well, will work with the stock rim 1 inch taller but same width so with a level there should be no rubbing issues, they should fill the wheel well a bit more, and dont need flares. Ill probably run a tread pattern like the terra grappler with some bmf or kmc xd wheels stock width and offset if available.
I would look in to 275 70 r20s if some one makes them, also being in canada the narrow tire works better in the snow.
So how are these tires wearing for you?
I just bought some Nitto Terra Grapplers (275/55/60) and I may change them out for your very tire (305/55/20E2).
However, I do have the stock 20x9" rims, so that may cause issues.
North Dakota has had a big oil boom the last few years. I was told that this is the only 10 ply tire a lot of companies are putting on because they wear so well.
Time will tell for me, but so far, so good.
Kyle
