Notices
WTB: Lots of parts for 1996 Dakota 2wd 3.9L
Old Jan 11, 2011 | 12:28 PM
1stGenDak's Avatar
1stGenDak
Default WTB: Lots of parts for 1996 Dakota 2wd 3.9L
I need...
----All four shocks (used and preferably aftermarket but factory is fine)
----ABS sensor that mounts on rear diff (so my dummy light will turn off)
----Rubber bushing that fits into the mounting slot on passenger side tailgate (very bottom where tailgate mounts to the body and rotates around)
----Used truck bed cover (preferably similar to Xtang Trifecta but something that is easy to fold up and remove for big loads in the bed)
----Large gray interior plastic trim piece that goes behind the seats (it is roughly 2' tall x 4' wide) I also need all mounting hardware for it
----Everything necessary to replace the bench seat to bucket seats (I hate not having an arm rest)
----Gray interior trim piece that goes directly under the steering wheel and all hardware
----All metal screws and clips that hold both the passenger/driver's door panels in place.
----Factory cd player or really cheap aftermarket one with all mounting hardware to replace my broken one
----Both windshield washer sprayers and whatever hardware is needed to mount...I do have the hoses but I don't know if there are any clips to hold them in place.
----4 lug nuts that go with the mag wheels
----Air cleaner metal pieces that attach to the throttle body and all mounting hardware
----Necessary equipment to swap from the clutch fan to an electric radiator fan
That should do me for right now. Some of this i can not afford yet, but I wanted to get the info out there so if you are working on a project you can set some parts aside for me. I am trying to stay as cheap as possible here, but the parts must be good.
Zac
Zac@jacksonvillekoisupply.com
