recon rear light bar
hello i just got my new 2011 ram 1500 and want to put on my recon light bar with reverse lights need the truck wiring diagram so i can hard wire it to the trailer pig tail . thanks for any help it does have the 4 & 7 pin plugs
just installed mine a few days ago, on recons site you can pull up the diagram, also when you go to hard wire it into the left turn signal, my light had a yellow a purple, and a ground, it was the yellow wire. fairly simple install once i pulled the diagram off recon's site. also if you have any doubts, you can make a small slit in the wire to test it, as long as you have your ground and 12v attached it'll light up!
http://www.gorecon.com/downloads.php
3rd cluster down, the first one is the general guide for which wires are which, then the supplemental for the xtreme just says hardwire the reverse which is simple
