Truck going to dealer today: Will report back
Old Mar 8, 2011 | 09:20 AM
dz302469's Avatar
dz302469
Default Truck going to dealer today: Will report back
My '09 Hemi Ram was taken to the dealer today for the following:
  • BAS/ESP light
  • Airbag light
  • Remote entry inop
  • power locks inop
  • power windows inop
  • wipers inop
  • HVAC inop
I'll post again once the dealer has the fix for informational purposes.
Old Mar 8, 2011 | 11:59 AM
BigBlueEdge's Avatar
BigBlueEdge
Dead battery, or battery with really low charge?
Rob
Old Mar 8, 2011 | 05:20 PM
roberttheall's Avatar
roberttheall
wired. did you check all the fuses first. it shouldn't be a dead or low battery. if the truck starts all that other stufff should work too.
Old Mar 8, 2011 | 06:16 PM
MADMAXIN22's Avatar
MADMAXIN22
sounds like a problem with the BCM
Old Mar 8, 2011 | 06:24 PM
BigBlueEdge
He didn't say the truck started.
Old Mar 8, 2011 | 06:41 PM
oldjeep's Avatar
oldjeep
Sounds to me like a loose connector on the bottom of the power center
Old Mar 8, 2011 | 07:47 PM
72combo's Avatar
72combo
I am with you oldjeep
Old Mar 8, 2011 | 08:03 PM
dz302469's Avatar
dz302469
Ok, dealer said he found some "loose wires" in the box under the hood?#$@?
It was fine on the way home. Wife picked it up so I wasn't able to question him
as to which wires in which box. Everything works now, for now.
Old Mar 8, 2011 | 08:04 PM
dz302469's Avatar
dz302469
Rob
Should have mentioned truck cranks and everything else works fine.
Old Mar 8, 2011 | 09:05 PM
reeseonfire's Avatar
reeseonfire
I used to work for Hyundai and they had major problems with the BCMs.
Especially annoying because the immobilizer was run through the BCM so you couldn't even put the car into "limp home" mode. Happy to say they've resolved all those issues.
