Need help removing radio faceplate on my 09Ram 1500
Help guys, I'm stuck!
I'm installing a lockpick and I don't know how to remove the 115V outlet cover to remove a mounting screw. I have the nstructions from the mygig forum, but I can't seem to figure out how to get to the screw. I'm afraid of breaking the cover.
I already have the shifter bezel off and the top two screws in the faceplate.
Thanks in advance!
Don
Thanks in advance!
Don
Try This.. http://www.wkjeeps.com/sound/2009_Do...io_Removal.pdf
The bezel will pry off...Use a small plastic fid.
I belive the holding tangs are at 9 and 3 o'clock........Could be wrong, it's been awhile since I've had mine apart.
Hi Thanks,
I finally used a little more force and I was OK. I just didn't want to break anything. The tabs for the115v outlet bezel are actually two on top and one below. Installed the lockpick and a backup camera.
Sweet!.
Thanks,
Don
Sweet!.
Thanks,
Don
